'Anti-Code' Opinions
On the plus side, when id does ignite when you're in bed it's under the dry wooden stairs to freedom so you'll all die together.
  • Replies 50
  • Views 11.8k
  • duh, the alarm is a security system which has requirement to have tamper circuit to detect tampering.   Gabs Security goes to Mrs Smiths house & fit a system, she gives the code to Robin
  • Nova-Security
    Nova-Security
    Accenta's had comms outputs and the anti-code was there to conform to ACPO requirements for a managed reset before DD243 came out.
  • well Robin did smash Mrs Smiths back doors in...
It's probably the original battery that's baking your power supply making it really hot. There may well be a voltage in the battery but chances are it's holding little to no Ah capacity. If it's that old it's probably broken or breaking down and pulling the life out of the power supply, hungry for the charge... but can't as it's goosed.
22 minutes ago, Gabs said:
they never even use the thing.
heat = energy
a cheapo battery might save enough pennies to pay for itself,
or do an MTA & twat if off the wall whilst your mate films it for youtube ?
Ha, how did you know it is under the stairs? :D All dying together because of the Paragon, has anyone ever come across a panel which has caught fire?
Well, last time we had a power cut, it lasted for the full two hours. 4 PIRs, and an SAB.
1 minute ago, MrHappy said:
heat = energy
or do an MTA & **** if off the wall whilst your mate films it for youtube ?
Ha, I've seen those MTA Systems videos on YouTube, funny.I didn't realise the Paragon was such a hated panel.
From the photo I can even tell you that standing on the street looking from the front of your home you live in the right hand house of two 1960's semi's, used to shop in Sainsbury's and are due a rewire in 8 years
Most engineers would see that as a benefit
Edited by norman
15 minutes ago, norman said:
From the photo I can even tell you that standing on the street looking from the front of your home you live in the right hand house of two 1960's semi's, used to shop in Sainsbury's and are due a rewire.
Hmmmm, you were close. But the house is 30s. Yes, probably due a re-wire, and no, Morrisons, always ;)
Edited by Gabs
No he wasn't, he was a s**t luser as always!
