Roller Shutter Doors Via Rela
Hello again...
sorry to do two posts in one evening.... i have a client who stores motor cars.. nothing amazing but they want to protect the roller shutter door so that if they intruder alarm is not unset the roller shutter door wont activate or open...
we use Texecom Premier 24 metal panels.. is there a way i could use a relay from the board to break the neutral via a replay so that when they alarm is unset the replay is not engaged... that way the doors wont have a circuit and wont open.. then when the alarm is in an unset state the replay is in tact and the doors can be opened??
geeky thinking but i like it!!
  • Replies 49
  • Views 9.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Your unbelievable.
  • Dont **** about with the mains to the roller shutter, the roller shutter should have a stop input for a safety beam. If it doesn't have a stop input for a safety beam its a dangerous pile of ***** tha
  • sixwheeledbeast
    sixwheeledbeast
    You shouldn't break neutrals for anything!   I imagine using a relay from a programmed output to trigger the emergency stop input?   Why not a lockable isolator?
its a huge advantage of Texecom diynot will cover most things
am i guessing this is possible then?? i use relays alot.. i have never used one in an alarm before and not sure if it will do what i want it too..
master what are you asking?
can i integrate the roller shutter door with the alarm??
In Alarm Set - Roller shutter door neutral broken via a relay powered by the alarm in alarm set state..
In Alarm Unset - relay closes and re connects neutral back to the door to allow the roller shutters to be used as normal?
you can use a roller contact but your wanting to use the rf one?
its ok james.. i think what i want it to do will work after reading texecom manual..
aswell as having a roller shutter door contact for alarm i also want to disable the electricity supply to the door via the use of a relay...
Think i have it sussed...
you what to switch the neutral on 230v garage opener to prevent the opener operating when system is set ?
10 amp relay, diode? Open close output
i would stick to house bashing.
Edited by whistle
