Informal advice on PIR positioning
They are good - but will be potentially blinded by the light / triggered by heat gains from those big windows.
You definitely want to consider a corner mounted, pointed away from window, dualtech i.e. MW/PIR DT  IMHO
TBH I only ever use ceiling detectors in wide open office spaces and as a last resort - if I had as good access as you seem to (I wasn't sure if you did being it was a flat) I'd go corners every time.
I was going to suggest a ceiling one, maybe, in that living space narrow bit, but I really wouldn't bother, tbh
Edited by datadiffusion
  • Replies 25
  • Views 10k
  • datadiffusion
    datadiffusion
    Nope, most manufactuers don't do door contacts - buy Knights or Elmdene, avoid DIY 'range filler' stuff like Honeywell contacts.   I would wire using EOL / FSL so be sure to buy contacts wit
  • datadiffusion
    datadiffusion
    They are good - but will be potentially blinded by the light / triggered by heat gains from those big windows.   You definitely want to consider a corner mounted, pointed away from window, d
  • james.wilson
    james.wilson
    al that joke is literally dead mate
Great help, thank you. I am sure I will have a couple more questions, but for the time being, I roughly know what is needed.
Going for Texecom Premier Elite range, wired. :)
You running any 12core in this system?
I was just going to use 4 core for the door sensors, and run 6 core cable for the PIR sensors...I don't need 12 core anywhere, do I?
4 core will do for most detectors if using EOL, although i usually use 6 core
if you do use texecom, the RKP has onboard zones too, so you can wire detectors back to there, gives you 10 zones without needing an expander
Did anyone send a card in the end?
  • 3 weeks later...
Morning folks, sorry for the delay, but a small update for you all, with the added Brucey Bonus of a couple questions! :o:D
In terms of cabling, I've run 6 core to most locations and ordered some Elmdene door contacts (flush mount for wooden doors, surface mount for aluminium sliding patio doors in living room / master bedroom, EOL resistors as recommended, so thanks for that! :D
In terms of PIR sensors, I've gone for Texecom's Premier Elite DT sensor, as recommended (thank you Mr DataDiffusion) so I get both volumetric and microwave coverage. So far, so good.
However, I still have some sensor positioning questions...pics to illustrate.
Locations #1 + #2 are fine, I think we agree on that. Main issue is what to do about the big open space that is the kitchen / living room?
(1) Location #5 is about 5.5 metres away from the large patio doors but still faces / look at them. This would cover the living room area. Is this an ok location for the DT sensor or should it be elsewhere in the room?
(2) I'd like a DT sensor in location #3 if possible, as that will cover anybody trying to sneak in via the bathroom...would location #3 be ok? I would like to avoid location #4 as it is directly above a vertical radiator, whereas with #3 it is further away from the rad.
(3) If I go with #5 and #3, because of the beam that is boxed in by the plasterboard, they wouldn't see each other hence won't false alarm? Or would they?!
5 is as good as it gets whilst still avoiding the rads...
3 and 4 for me much of a muchness, if 3 is a little bit further from the rad, that's possibly better.
The microwave beam can go through walls - but that's why it's adjustable to prevent that when it's installed.
