Texecom Premier Elite Wired vs Wireless
Pretty simple really...I've narrowed down my choice to the following kit -
Texecom Premier Elite 48
Wireless Expander
7 Dual PIRs
4 Impaq Shock/Contacts
GSM Module
ComWIFI
Bell Box
Difference in costs between a wired vs wireless is that the wired in about £400 cheaper. I a veering to wired because im not sure on wireless reliability, cost is not the factor here. However when I look on the texecom site its heavilly investing on the Ricochet tech & wireless.
So should I stick with Wired or go down the wireless route? and if wireless - why?
Thanks Gents!
Before you embark on such a project, have a quick read of these 2 recent threads;
and
  • 1 year later...
I like them both on the Texecom, if you go wireless i always try to get at least the SAS wired, its generally the thing that causes most hassle, certainly has been temperamental on Texecom.
  • 5 months later...
In my experience the texecom wireless stuff is very reliable, the only thing that has been a bit buggy or tricky is the smartcom, which you would be using for app access on the wired system also.
For overall ease I would go wireless and have it finished in half a day.
On 22/11/2016 at 10:32, sixwheeledbeast said:
Personally I would always wire if possible.
messy on windows if they dont let you drill them windows proper
Depends on the job and the windows. End game is the customer is protected and happy with the system.
Done a good few hybrid with shocks wireless and everything else wired.
Many think your going to rip there house apart to get cables in and most times there is no need.
You think the wireless sensors are better than wired shock? Taking into consideration the wireless shock can be adjusted on software side ?
No. You need to be in front of the device to test during setup or adjustment.
Remote adjustment offers nothing here IMO.
