Keighley Posted November 20, 2016 Share Posted November 20, 2016 just replaced a blown caps on the main board of a veritas R8 alarm got everything working again the only thing that I cannot do is it is programed to accept to arm it with just pressing full or part and I would like to have to put the user code in then full or part I have looked but cannot find a answer I know I will get a answer here thank you in anticipation Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 20, 2016 Share Posted November 20, 2016 If you have blown caps it's likely to be old and not have the one button set feature. Red LED on CPU? Quote Link to comment Share on other sites More sharing options...
Keighley Posted November 20, 2016 Author Share Posted November 20, 2016 yes it does it all works now but it arms with just pressing full before it blew I had to put the user code in then arm  Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 20, 2016 Share Posted November 20, 2016 you want 1 button set enabling or disabling ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Keighley Posted November 20, 2016 Author Share Posted November 20, 2016 (edited) disabling I want to put the user code in then arm Edited November 20, 2016 by Keighley Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted November 20, 2016 Share Posted November 20, 2016 So it has a RED LED and you can just press full? Pretty sure it doesn't have that option. Later models are Menu 00 option 3 Quote Link to comment Share on other sites More sharing options...
Keighley Posted November 20, 2016 Author Share Posted November 20, 2016 there is no red led just the green one Quote Link to comment Share on other sites More sharing options...
Keighley Posted November 20, 2016 Author Share Posted November 20, 2016 (edited) here is a photo of the key panel in the manual it says that it can be programed so it is a one button arm via the engineer code but it doesn't tell you how or how to disable it Edited November 20, 2016 by Keighley Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted November 20, 2016 Share Posted November 20, 2016 I am pretty sure he means the single led in the middle of the large white system box, rather than the keypad Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands  Link to comment Share on other sites More sharing options...
Keighley Posted November 20, 2016 Author Share Posted November 20, 2016 there is only one green one at the top and in the centre Quote Link to comment Share on other sites More sharing options...
