Problems with Honeywell AG6 bell boxes.
I really cant see that can be happening on ac fail if its wired like that
Can you replicate it?
  • Replies 37
  • Views 19k
  • I agree - previously had to apply silicon sealant around rear of box and where cable enters (picture) as water did run along this.  The last two times the water has capillaried from the bottom edge in
Al-yeti,
I'll get some photos of the circuit boards and terminals as soon as. I know there has been water ingress on the bell box that I don't think activated as I've drilled some drain holes in the outer casing. However, it never reached the pcb only the status LED and corroded the legs, but it still functions.
James,
Yes, I want to do a full replication/full test as soon as, only one problem - the piezos.
Is there a way to muffle them? I've tried stuffing cotton wool into the cones and taping over holes but it has little effect on the sound level.
Is it feasible to attach LEDs in their place to act as activation indicators?
Tom.
no the piezos run at high voltage.
what happens if you disconnect the battery on the sab that is misbehaving?
34 minutes ago, Tommygunn said:
Al-yeti,
James,
Tom.
How do you know it didn't dry off on the PCB , was enough to short it , I have seen it on these bells before because of how cable is taken in and where rain has hit got behind it
Maybe yours survived but symptoms were similar and you confirm now water got in
PS if it's quiet you could disconnect them, make terminal on them, and you will here oscillation when activated
I've had a about three Honeywell bells randomly chirp then go off for no apparent reason in the past (usually when just out of warranty) - everything checked out ok with the rest of the alarm when tested
(No sign of any water ingress either)
Swapped them out for texecom bells & not had any issues since from those systems..
Water ingress dodgy fitting or other
Gents,
Thanks for the input so far. I'll have to back to this at the weekend as things are a little busy at the mo to go scrambling around on the roof and what not.
Cheers,
Tom.
I would say other, no sign of any water ingress, cable was not installed in such a way so water would track through to the bell.
I
Ok, I've taken some photos and done some tests and below is what I've observed.
First, I conducted a manual test of the bell boxes, via the LCD keypad option, and both piezos sounded at the same time with the correct high/low siren.
I then did a full alarm activation and everything worked as it should except that the 'rear' bell box just gave out regular high pitched beeps while the 'front' bell box gave out the correct high/low siren signature. Also, of course, no strobes for either bell box.
I also replicated AC power loss but to no avail, none of the bell boxes sounded.
Front bell box:
Fully functioning piezo, non functioning strobe and no water damage.
Rear bell box:
Partially functioning piezo, not during full alarm, non functioning strobe and water damage.
Tom.
Edited by Tommygunn
Bottom two pictures definately have issues with water damage. Bin.
Personally I would buy quality sirens like Texecom. Elmdene etc... where the electronics are enclosed.
Edited by datadiffusion
