Hi Guys,
I currently have a 6 year old, wired, Nexus 8 intruder alarm. The PIR in our kitchen was damaged by painters the other day so I am going to have to replace it. My wife's friend works for an intruder alarm company and gave her a Honeywell DT7550UK2 Dual Tec sensor. Was just wondering how I should wire it in? I have attached a photo of the current sensor PCB and the new dual-tech one.
All help appreciate guys.
Best Wishes,
Matthew
Attached is a photo of the new sensor!
Thanks, Mark - that new one is probably to 'high tech' for a domestic. Wouldn't you agree? Ah, well...it was free.
Any tips on how to prevent the alarm going off outside/electrocuting myself?
Thanks! :)
open the main control panel, silence the alarm, locate the 12volt aux supply to the detectors (red and black wires), disconnect those, replace the pir, the reconnect them, close up the panel and reset the system. should be good to go!
and yes, its a bit overkill,  but for £0 i dont think you can complain ;)
Register a new account
Sign in
