bornstubborn Posted February 3, 2016 Share Posted February 3, 2016 Hi, I've got a galaxy flex 50 I installed myself which has been running fine for a few months, linked to selfmon and happily sending event alerts by email - using the Honeywell Ethernet module. I was making some changes to my Internet configuration and had the panel disconnected for the internet for a period of time. I've since got it reconnected and am able to connect from to the panel over Ethernet, however I cant seem to clear the fault from when it couldn't connect out. The panel displays "system fault reset required". I can enter mgr mode and see 3 faults - comm fail arc, comm fail rec1, +hb fail comm 4. I can press ent to continue, then enter engineer mode, but cant find how to reset these faults. exiting engineer mode runs through the normal checks but the faults persist. can anyone help? thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/ Share on other sites More sharing options...
JB_ Posted February 3, 2016 Share Posted February 3, 2016 I was making some changes to my Internet configuration Would that mean new router so different gateway IP that needs updating in the panel? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439848 Share on other sites More sharing options...
bornstubborn Posted February 3, 2016 Author Share Posted February 3, 2016 Hi, thanks for the reply, no, same router, subnet and gw. I can ping the Ethernet module from the router. I was actually just ripping everything out of my cabling cabinet and redoing it all neatly! It meant the panel was offline for several hours. with hindsight I should have disabled the arc settings before hand. Thanks Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439850 Share on other sites More sharing options...
al-yeti Posted February 3, 2016 Share Posted February 3, 2016 Restart panel Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439851 Share on other sites More sharing options...
GalaxyGuy Posted February 3, 2016 Share Posted February 3, 2016 As per Al's advice, restart will flush the errors. The other (correct) way is to send two successful events to selfmon (eng tests) and then enter as engineer and view the faults to clear them. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439857 Share on other sites More sharing options...
james.wilson Posted February 4, 2016 Share Posted February 4, 2016 BT had an outage, all broadband went down, possibly related securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439866 Share on other sites More sharing options...
bornstubborn Posted February 4, 2016 Author Share Posted February 4, 2016 schoolboy error, I could get to my router, but hadn't realised my router couldn't get out, hence no comms with selfmon and the resulting error. fixed this and error has cleared. thanks everyone! out of interest, what is the process to restart the panel? Does exiting engineer mode do this, or is there another way of rebooting the system? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439879 Share on other sites More sharing options...
james.wilson Posted February 4, 2016 Share Posted February 4, 2016 restart option in menu 51 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/39710-fault-reset-galaxy-flex/#findComment-439881 Share on other sites More sharing options...
