Increase In Wireless Issues
GalaxyGuy
https://www.coolcomponents.co.uk/rf-explorer-3g-combo.html
They are good for the money. Fragile though - power switch and USB has broken on mine and it's always been taken care of.
It will pick up most accidental sources of jamming, but miss intentional because of the slow sweep speed. A SDR is better to pick up intentional jamming.
http://cybergibbons.com/
A thing you plug into your computer, it receives a wide-ish bit of the spectrum (5MHz-100Mhz, typically), and you can show it on your screen as a spectrum or waterfall:
http://nansupport.com/images/rfexplorer/heatmap-800x349.png
Difference between the RF Explorer and SDR is that the RF Explorer sweeps - starts at 858MHz and slowly goes up to 878MHz, whereas an SDR can receive the whole 20MHz instantly. Just means you can miss things.
