Zone Fault On House Burglar Alarm
sean5302
I forgot the 9448 was the bum basic version, you might be ok. Walk test first and report back. Do you have any electrical knowledge? Can you work a multimeter to measure voltage and resistance?
But tbh a pro is best. The last thing you want is to cause a short, electrocute yourself or have a system that false alarms or fails to perform when needed.
Accenta mini g4 bell box an pirs, les thank £100 get it fitted in about 2 hours fir less than £100
Pretty stable for a cheap replacement really
Come on man, you won't cable 8 zones under floors in 2hours
You fit direct under carpet? Everything on skirting clipped?
I assume new devices on old cables, he's also self employed ?
Thats ridiculous.
