Removing A Texecom Veritas *rolls Eyes*
Hello,
Well had to go to a customer property to remove Texecom Veritas system.   Various reasons customer want alarm removed but thats a other story.
This system is hardwired in as normal.
Went about to Set system into Light only mode, simple
Remove Bell Box, Simple
Went to Panel removed battery, Simple
Went to remove fuse spur, It was not fused in!
Looked about to try find mains cable, This is put inside wall and was actully connected to the Bathroom Extractor spur!
Have anybody ever come across this or a weird way to wire in alarm.
Panel installed over 'passing by' vertical ring main beneath plaster.
Cut down to sheath with knife, tripled up security cable wires soldered on, no earth (plastic panel innit?), mastic applied before gluing panel to wall
This was when we were upgrading someones existing back in the mid to late 90s. Well before cheap digital cameras and phones.
At least they brought it out to a spur! :no:
We had a funny one once where the alarm 'went funny' every time they went in the cupboard.
Some joker had wired it to the switch (i.e C and L1), and being a few years ago the filament of a 60W lamp was more
than enough to take the current of a small transformer. Of course turned on this then cut off the alarm which briefly
went into mains fail until they'd finished in the cupboard.
Every little helps
Done to death 2 years ago!
