Pyronix Tmd15
hi
I have purchased a pyronix tmd15 off eBay and I would like to know the correct way to conect to a scantronic 9600
many thanks
How are you going to use it? As two independent detectors or one tri-mode detector?
as the 9600 does not support EOL or masking.
It's so retro it barely supports anything other than a keypad and 8 CC alarm and tamper inputs! :)
I was amazed myself the other day having a look at it, how tiny the manual actually is to how I remembered it...
you could add 2 z 4 DP input cards to make it a whopping 16 inputs.
When I worked for Essex Security we had one connected to a smoke cloak and the 9600 was so limited, we could not monitor the fault outputs.
its got molex pins for a Stu what more do you what... old alarms & heating controls are quite common, but everything else has been renewed more than once,
