al-yeti Posted February 20, 2014 Share Posted February 20, 2014 GD520 line 3 First smart Rio - ok Second rf portal - ok Third keyprox - stars only Fourth keyprox - ok Fifth mini Rio -,ok Sixth touch centre 680ohm -okish So the third is a keyprox which won't respond to any address The last being a touch centre works but the display is flickering slightly ie brightness oddly enough so is the third keypad , even though tried adjust the keypad address 11mods without that line 19mods with that line connected Tried another keypad same thing , flickering is odd as connecting touch c alone no flicker Link to comment Share on other sites More sharing options...
james.wilson Posted February 20, 2014 Share Posted February 20, 2014 What's the volt drop at the touch. put one of the working keypads at the star location if it works then id say you have a duff keypad. Also check voltage at each keypad securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
al-yeti Posted February 20, 2014 Author Share Posted February 20, 2014 Ok will check on those tonight! Strange though I must have a dud keypad as I tried swapping it out I get back to you Link to comment Share on other sites More sharing options...
al-yeti Posted February 20, 2014 Author Share Posted February 20, 2014 Just quick thing could it be an invalid address being used for example will the keyprox be valid on line 3 as an address for example c I seem to remember some settings not used and I might have missed that, will check later don't have access til 9pm lol Link to comment Share on other sites More sharing options...
9651 Posted February 20, 2014 Share Posted February 20, 2014 what address is the touchcenter? Conflict with RKP 3 if you recon the touchcenter isn't well? Whats the diag readings of the devices? Link to comment Share on other sites More sharing options...
timmo66 Posted February 20, 2014 Share Posted February 20, 2014 Conflict of addresses? As said, swap three and four around and see what happens. Have you come out of engineer to accept new devices? Could also try a restart from parameters menu. Link to comment Share on other sites More sharing options...
al-yeti Posted February 21, 2014 Author Share Posted February 21, 2014 Doh James gets it Second new keypad was duff aswell weird put a third on came straight up after exit Also 11.5v at all pads approx probably why touch centre is flickering any tips on the smart Rio output? Havnt gone to far into that yet, thanks Link to comment Share on other sites More sharing options...
matthew.brough Posted February 21, 2014 Share Posted February 21, 2014 11.5v Oh dear www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
timmo66 Posted February 21, 2014 Share Posted February 21, 2014 You may need to move the smart rio further down the data line. And don't forget to leave your inbound postive OUT at the smart rio. Link to comment Share on other sites More sharing options...
matthew.brough Posted February 21, 2014 Share Posted February 21, 2014 Seen that many times where the +12v is paralleled up. Can't get the staff these days . . . www.securitywarehouse.co.uk/catalog/ Link to comment Share on other sites More sharing options...
