Something Cool
A certain panel can also do this via macros so the turning off could be x minutes after the system has set so you get chance to lock up and in the car before the lights go out.
If you ask your alarm company nicely they might give you a set of relay contacts for your electrician to wire to
In fact I'd go so far to say if your alarm company won't do it free if charge as the panel already has clean contact relays in then they are no good and you should look elsewhere.
id disagree
