September 19, 201312 yr comment_345753 Recently installed an informa speech dialler to a honeywell controll panel and its not dialling when the alarm been set. Instead it dials out as soon as a user password been entered to stop the alarm. I did a alarm output test on the controll panel and its dialling straight away. Then I did a dial test through the speech dialler and its dialling fine. But when the actual alarm been set its waiting for the user to enter the password n then it's dialling. Contacted honeywell and they haven't got a clue.they asked me to put a new controll unit n a new dialler and see. I did but still the same problem. I wonder does any one else encountered this. Pls share your thoughts. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 19, 201312 yr comment_345777 You need to invert your trigger securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-345777 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 20, 201312 yr comment_346003 You need to invert your trigger and possibly fit 'pull up' resistors, should be in the dialler instructions. If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346003 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 22, 201312 yr Author comment_346211 You need to invert your trigger Hi jameswilsonCould you please explain how to invert the triggers ! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346211 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 22, 201312 yr comment_346213 Hi jameswilson Could you please explain how to invert the triggers ! Be helpful if you let us know which Honeywell panel? www.securitywarehouse.co.uk/catalog/ Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346213 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 22, 201312 yr comment_346216 It will either be an option in the panel programming or a jumper etc on the dialler securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346216 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 23, 201312 yr Author comment_346262 Be helpful if you let us know which Honeywell panel? its Honewell Accenta (8SP399A) mini control panel with lcd keypad Honeywell ADE Informa Speech Dialler (8EP276A) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346262 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
September 28, 201312 yr Author comment_346956 It will either be an option in the panel programming or a jumper etc on the dialler hi, you were right, I found, I have connected the telephone cable other way around. now its working fine. tx for all of your suggestions on this topic. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-346956 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 19, 20215 yr comment_508712 Hi Pradeep So, I know it was some time ago that this was posted but i have the same problem. when you say you connected the telephone cable the other way around are you referring to the PCB terminal on the speech dialler A and B and changed the Red and White wire the other way around as in terminal A Red instead of white and terminal B White instead of Red. Regards Derek Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-508712 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
February 19, 20215 yr comment_508713 Has this started happening recently? ie did it used to work. What exchange are you connected to and are you aware of BT pstn switch off? Sorry just read the OP Id assume you have your triggers wrong way around securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/35336-informa-speech-dialler-only-dials-after-entering-the-password/#findComment-508713 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
