Hiding Wiring
RichardAirey
Dear Friends,
My current alarm panel is over 20 years old and I have decided enough is enough
I have decided to go for a veritas R8.
The panel is located in the hallway about 3 meters from the front entry, shoulder height in clear view.
Since relocation will cost alot more instead I wish to mount the R8 main box high enough so that a ladder is needed
MY QUESTION:
To do this I would need to extended some wires to reach the raised box, how would I go about hiding the Terminal blocks
which are at shoulder level?
Is there a smaller alternative to using terminal blocks?
Thanks is advance!
Not wishing to put you off upgrading, but I'd be inclined to start again.
New panel, detectors & wiring (as you wish to resite the panel). Additional cost would be minimal - click the sponsor link above for prices.
If you must do junctions I'd solder joint & heatshrink sleaving.
Dear Friends,
MY QUESTION:
Thanks is advance!
or just replace it with a new panel with onboard keypad that looks ok in the hallway
Ensuring that it conforms to EN 50131-1 as well then ?.
if its a diy then no need.yale do some decent looking kit aimed at the diy market.with some good looking features,never used them but they look ok on first view
