Bell Box Bracket Required (i've Lost It!)
Hi,
The builders have finally finished rendering and I thought I'd put our Telecom Security (dummy) box back up. I have the box, screw and the cap, but I can't find the bracket anywhere! Is the L-shaped bracket a standard fit, the likes of which I may find at the DIY stores?
Thanks
www.wiinetwork.co.uk - Nintendo Wii Worldwide User Map
Hi,
Thanks
i don't know about this bracket usually a decoy has a back plate or only a mild steel strip bent to suit,
just don't ask for the engineers code or manual for it lol
regs
alan
:rolleyes: If all else fails, a very long screw(!) through the existing hole into the brickwork will do...
Well, that won't work will it, the lid to bracket fixing is at the bottom.
Im sure it soon could have!!!
try any diy stores in the bracket department a normal l shaped brack should do id have thought take a look at the drawing supplied.
I see this piece of advice is yet again potentially dangerous.
Assumptions been made that the op is capable/competent/able of carrying out said procedure with due regard to regulations.
I refer of course to the oft ignored Working at Heights Regulations.
For those who may consider this unimportant, may i refer you to;
HSE. The Work at Height Regulations (2005) as amended, a brief guide. para 2
As is often quoted. Ignorance is no excuse.
Good point Cubit.
In addition we don't know the OP's medical history.
He will experiance acute vertigo if he suffers from a middle ear infection, middle ear inflammation, M
