- Past hour
riccardo joined the community
Infinite prime control panel
Technott joined the community
That's the one I salvaged the piezo element from, which is working fine now in the HKC one. So does anyone know whether 120 V AC is a standard voltage for these?
Who's Online 1 Member, 0 Anonymous, 53 Guests (See full list)
Total Topics446.3k
