- Past hour
Visonic powermax help needed please
naeem7861 replied to naeem7861's topic in !!..DIY Installers..!!
Hi thanks for getting back to me so you can only use the this panel with the same frequency devices correct ??? - Yesterday
Hello everyone, I need your help! I'm installing a RISCO LightSys plus panel with the wireless module. The house is very large, so I had to use repeaters. However, after finishing the programming of the sensors, there is a download of the "Repeater.BIN" file between the panel and the repeater, and this download always fails, causing the detectors to never stay on the repeater. Does anyone know how to solve this? Thank you.
Hello everyone, it's a pleasure to be here. I'm an engineer from Portugal
Yes it's different.
I am replacing an existing old bell box with a Reson 8 bell box 8EP420. My alarm panel is a Optima G4. They are connected via a 4 core cable. The existing panel wiring is as follows: Panel Bell box Strobe+ (no connection) A link between T and A Strobe- (yellow) A (blk) SCB D (red)Bell+ B (blue) Bell- The Reson8 install guide only shows a 5 wire system: Panel Bell box Strobe- Stb- B (Bell-) Trig- A- Hold off - D (Bell+) Hold off + T- Rtn - I cant work out how I should wire the Reson8 from this. Any Alarm installers able to offer advice? Quote Reply to BernieA Report •••
I believe different frequency prevents the use of normal visonic devices
james.wilson replied to naeem7861's topic in !!..DIY Installers..!!
You can but we don't give advice on how to defeat systems which a default does. I'm sure you are genuine but others are not. Not sure if aft badged gear has different firmware stopping it's use as generic visonic maybe someone else here with experience knows? -
Hi James also can I factory reset the codes to default would be greatfull -
It's a powermaster 30 can it work with the visonic go app -
Hi sorry yes it's a powermaster - Last week
powermax as in the really old one or powermaster? -
naeem7861 started following Visonic powermax help needed please
Hi I got a visonic powermax alarm unit it works fine but needed to know how todo part settings for alarm to arm door contacts for night only any help would be greatfull thanks
Secure I Am joined the community
maxxo joined the community
Hi Flavio Unfortunatly most here are pro engineers and wouldnt touch diy grade stuff. I dont have anything like that
fantasticmoebius joined the community
Hi everyone! Trying to help my dad here. I've installed a Yale SR-330 Smart Home System. But it was partially fried during a thunderstorm. It turns on, but an intermittent beep keeps sounding off when turned on, and the yellow light turns on. I'm not in Uk and there isn't anything from Yale to purchase here in Brazil, much less an older, outdated system. But I'm chasing the Yale SR Smarthub 2.0 Schematics to download, and can't find anything. Can any of you help me on this, please? Thanks, Flavio
Agreed if start with 1 circuit and work from there. Link out all circuits then start with 1 find out what's wrong with it move on. Start with resistance and voltage etc
I had also had a glass place, Large workshop no detection 9448 or similar in an office block, equally crap fire alarm... Thomas Higgins letter than ccj for a few hundred quid of work (iirc)
Dude forget eol If you wired tamper and alarm , linking the zone clears the led as you say , Does it do that on a zone connected to a PIR? If yes reconnect wires , join the alarm wires at the PIR , does it clear the led ? On setting There's simple methodical approach to this Just like you would fault find on electrics ? Unless your just first fix then I understand your current approach , (current unintended pun but I think I might use it again )
Just don't... the basic stuff is the hardest because there's no proper logs or diagnostics, Something like a euro mini would say something like Fuse Failure 100 31/05/24 11:30, Silenced by user 1 31/05/24 11:33 You then replace the fuse, note the landing sensor does not light up, look in the loft to find a rat has chewed the wire or whatever Alarms are a massive pain the balls, don't get involved.... I regret getting involved In the words of Zammo Maguire - Just say no...
I can do basic alarm installs but not had much experience with alarm fault finding but every ones got to start somewhere. The reason I asked on here is because people have experience with different alarms and could be a simple fix
Who's Online 2 Members, 0 Anonymous, 121 Guests (See full list)
33.2k
Total Topics443.8k
