- Past hour
monena joined the community
riccardo joined the community
Infinite prime control panel
Technott joined the community
Battery not at fault, it was the piezo element. However HKC say the battery should be good for 5 years, and now it's 8 years. However I tested it, and it can still power the sounder for the 15 mins set by the jumper.
Who's Online 1 Member, 0 Anonymous, 46 Guests (See full list)
Total Topics446.3k
