- Past hour
Infinite prime control panel
Battery not at fault, it was the piezo element. However HKC say the battery should be good for 5 years, and now it's 8 years. However I tested it, and it can still power the sounder for the 15 mins set by the jumper.
Who's Online 1 Member, 0 Anonymous, 46 Guests (See full list)
Total Topics446.3k
