Card types and how to get the head around?
james.wilson replied to Cieska's topic in General Security & Fire Queries
I dont know of any training courses for that -
Cieska replied to Cieska's topic in General Security & Fire Queries
At the same time, where would I get such training or knowledge related to card technologies in real life? -
Small scale manufacture pre 1970's would probably be on breadboard ? There are chunky but modern looking resistors & capitors. All components are marked in white text along Co. Name & model no.. Use of slotted screws say built up without power tools A 4x4 box is very heavy duty or predated the plastic alarm cased detection of the 1980's ? I've never seen one before or heard of the co But item would have probably been in warehouse or similar & probably quite pricey in it's day
Seems GJD bought them in 2017 probably sacked everyone after that and lost all old data but you never know they might have some info for you
The PCB material makes me think 70s. The capacitors maybe look more modern? It's probably hard to date if they would have been hand built and low batch numbers?
The first production of an Led was 1962
You looking in mirror on a good day?
Mr Happy, what makes you think it might be 1970’s, is it the wiring colours or the style of the components?
Thanks guys, those are helpful comments and confirm my thoughts although it’s useful to hear how they might have been used. When cleaning them yesterday I noticed that the single lense was red but the twin lenses are black, similar to welding goggles. I presume that the red would be the transmitter as there is a diode behind the internal curved lense?
Looks 1970s to me ?
Radiovisor specialised in Active IR beams. Never seen any so old tho. They work as a pair. Usually an IR beam is emitted then reflected back it detects if something blocks this.
They look like early IR beams transmitter and receiver.
Hi All, I’m new here and a fraud as I don’t install security alarms but came across your forum when searching Radiovisor. I’ve just picked up from a house clearance sale two intriguing wall mounted Radiovisor devices that seem to use infrared and I wanted to try and find out their original application. I will try and attach pictures but they are both around 6” square and 4” deep, one having a single lens and one having twin lenses. They are badged “Radiovisor” and inside have the type BA500T. They appear to be from the 1930-40 era but bear no dates. Can anyone give me any clues as to where they would have been used and what for as I’m intrigued by them? They’re going on the wall in the utility room, come what may, but I’d like to find out about them if I possibly can! Thanks for any help you can give! Paul King, Kent
Eaton KEY-KPZ01 rapid red flashing
al-yeti replied to AutomationEng's topic in Control Panels (Public)
Althought have you managed to delete the keypad? And need to add it back as a device Does the app allow a virtual keypad? Go through it and see if it sees keypad or not as a wired device -
Maybe then keypad issue -
james.wilson replied to AutomationEng's topic in Control Panels (Public)
Agreed sounds like a keypad comms issue. However I'd thought you would get faults reported / logged -
Cable fault, I assume it worked on the bench with short cable or check there's no strand shorting out where you connect wires, if spare cores try them instead to keypad -
I programmed an i-onG2SM, in my office. PIRs door contacts, KEY-KPZ01 and network access. Everything worked OK. II then connected it to the actual system, replacing an old Ademco Galaxy. The only thing I didn't connect was the bell box. I also only had the keypad on a short wire, local to the box, while I tested everything else for a few days. This also worked. I have now connected the bell/ strobe and used the old wires to replace the Galaxy keypad with my KEY-KPZ01. For some reason the keypad will only constantly display the Eaton logo and an old date, and the navigation button rapidly flashes red. Pressing any key just causes a beep but does nothing else. The system still works through the Secureconnect app. but I can't do anything with the keypad. Any ideas would be much appreciated. Thanks in advance
I was told that I could read the number simply when reading the card. So I guess it is not encrypted. Otherwise, I won't be fighting here. The dashes in Sectors 1 and 2 are because I would think I read this card with mobile NFC? or should I consider something not good here? Well, I'm first time using this mobile app to read the card. -
Using an old PM360 ADT Alarm System
PeterJames replied to Juan Pablo's topic in !!..DIY Installers..!!
Good old Github -
I assumed spam, but looks like good info
james.wilson replied to Juan Pablo's topic in !!..DIY Installers..!!
I need to review links but I'm away from a desktop. -
I'm kind of late to the party, but the final answer to the OP question came in just a few days ago. Between heating and eating I chose... to cancel ADT subscription. At the time of the separation, ADT didn't offer any codes. Fully functional Visonic PowerMaster 360 professionally installed system became abandoned as a result primarily because of the inability to check it via the app remotely. Many thanks to Visonic Powermax and Powermaster Integration for Home Assistant OSS project, it is possible to give Visonic PowerMaster 360 a second lease of life without paying for a rather expensive and totally useless subscription. As a byproduct, the following secret codes, not shared by ADT otherwise, can be extracted from Visonic Power Master 360 and a few other panels on the list: User Codes Master Code Installer Code Master Download Code Installer Download Code Raspberry Pi Zero (£12.59 inc. VAT and shipping) will do the one off code dumping job. It will require a quality micro USB cable, a phone charger with micro USB output and an ability to follow unwritten instructions. NB Raspberry PI Zero doesn't have any network connectivity, so it will be useless for anything else. Although I have some positive experience of running Home Assistant on a sister SBC with 512 MB RAM and Wi-Fi (Zero 2W), Home Assistant hardware requirements are hugely and unreasonably inflated when it comes to RAM. Well, the internet if full of opinions and alternative facts. The panel is self contained. No cloud is required for it to operate. By plugging Home Assistant via Visonic Powermax and Powermaster Integration into PowerLink subsystem via a micro USB connector at the back, the panel is getting an ability for integration with Apple HomeKit, or any other home automation controller either natively when supported, or via MQTT. In addition, the GSM module inside the panel can be configured to send alerts via text messages. Apparently this will require a SIM on a paid contract. As a reminder, the GSM module is 2G/3G, and 3G will not exist in the UK beyond next year (with exception for so much lobbied smart meters, of course) and 2G will be switched off by 2033 at the latest.
Who's Online 0 Members, 0 Anonymous, 111 Guests (See full list)
33.2k
Total Topics443.8k
