- Past hour
or you've had your brains bummed out..... - Today
Infinite prime control panel
Its unlikely anyone here would know it was a primarily DIY product, my best guess would be to change the wireless codes, very early wireless stuff allowed you to set codes so that it did not interfere with neighbours alarms and vica versa - Earlier
Battery not at fault, it was the piezo element. However HKC say the battery should be good for 5 years, and now it's 8 years. However I tested it, and it can still power the sounder for the 15 mins set by the jumper.
Who's Online 1 Member, 0 Anonymous, 57 Guests (See full list)
Total Topics446.3k
