In 2025, the security challenges faced by businesses across the UK have become more complex than ever. From increased break-in attempts to the growing need for site supervision outside of standard hours, the demand for advanced remote CCTV monitoring is rising rapidly. Remote monitoring allows business owners to maintain 24/7 surveillance of their premises without the cost or risk associated with traditional, on-site security. Whether you're operating a retail outlet, managing a warehouse, or securing a construction site, this technology provides real-time visibility and response across multiple locations. Here are a few reasons why remote CCTV has become a cornerstone of modern business security: Immediate Incident Response – Monitored systems can detect unusual activity instantly and alert the appropriate response teams. Operational Efficiency – Businesses save significantly by reducing the need for physical security presence. High-Quality Recording – Events are captured in HD and securely archived for future evidence or insurance purposes. Scalable for Growth – As your operations expand, remote systems can be integrated across multiple UK sites with ease. Staff & Asset Protection – Deters theft, vandalism, and unauthorised access before it happens. Remote CCTV isn’t just about catching intruders after the fact — it’s about preventing incidents altogether. Many UK businesses have already made the switch to off-site video surveillance, especially in sectors such as retail, logistics, and construction. Has your organisation adopted remote monitoring yet? I’d be keen to hear what systems others are using and what results you’ve seen in terms of security improvements or operational cost savings.
Thanks for the reply. Regarding the guard access, as far as I can make out this only allows you to pass through a zone on your way to the keypad once the entry timer has been tripped. The problem I'm having is that in part set (Going to bed) I require zones 1, 2, 3, 4, 5 and 8 (All of downstairs and upper rear bedroom windows) to be active, zone 7 (Landing) to be off and zone 6 (Stairs) to be timed. The idea being that we are able to move across the landing in the night to visit the bathroom and then when going downstairs in the morning the stairs sensor will trip the timer to remind certain individuals to disarm the system. The reason behind this is that on numerous occasions in the past these certain individuals would walk down the stairs, right past the keypad at the bottom of the said stairs and into the living room, thus triggering a full alarm and therefore awakening the whole house, by adding a sensor on the stairs that trips the timer, I hope to overcome this. (Although having known these certain individuals for quite some time, this is by no means a certainty........ !) As mentioned earlier, I can select the "Alter Part Arms" menu and select each zone to be on or off in part set, but on or off are the only options available for the zones in that menu, there are no other options like setting a zone to be timed or entry / exit. I've looked through all of the programming menus and cannot find anywhere that gives me an option to program zone 6 as timed or entry / exit when the system is part set. I'm certain that this can be done, it's just that I can't suss out how.......... So it's back over to the good folk on here to hopefully help me over the line with this one...... Regards, dave. - Last week
Guard Access ?
Who's Online 0 Members, 0 Anonymous, 58 Guests (See full list)
Total Topics446.4k
