Carlos Arruda Posted May 30, 2016 Share Posted May 30, 2016 Hi all. I have a friend who has a Visonic GE350-ATS4 installed in his house. The system has worked flawlessly for the past 2 years but now it has develop this beep every minute. Now, I have never done security alarms, my background is fire alarms and I'm an electrician by trade. As a very good friend of mine I decided to look into this issue. Sadly, he does not has the manual. Anyone knows what this beep refers to or where can I find the manual? A google search was not productive. Many thanks. Albert Quote Link to comment Share on other sites More sharing options...
norman Posted May 30, 2016 Share Posted May 30, 2016 Check his smoke detectors before you waste any time. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
lymebayalarms Posted May 30, 2016 Share Posted May 30, 2016 2 hours ago, norman said: Check his smoke detectors before you waste any time. ...come on, we have all fallen for it right! Quote Link to comment Share on other sites More sharing options...
Carlos Arruda Posted May 30, 2016 Author Share Posted May 30, 2016 Fire alarm is a completely independent system. Thanks Quote Link to comment Share on other sites More sharing options...
Night Owl Posted May 30, 2016 Share Posted May 30, 2016 2 hours ago, lymebayalarms said: ...come on, we have all fallen for it right! Yes.. haha.. replaced all the batts and still getting a beep..but system is clear of errors. Bloody Co2 alarm in same room as panel was flat. Quote Link to comment Share on other sites More sharing options...
Night Owl Posted May 30, 2016 Share Posted May 30, 2016 8 hours ago, Carlos Arruda said: Hi all. I have a friend who has a Visonic GE350-ATS4 installed in his house. Many thanks. Albert I believe the GE350 is refernece to GSM module. What is the panel? If you don't know look here and see if you can recognise it? You should see a warning indication on the panel, might be low batt. Quote Link to comment Share on other sites More sharing options...
Carlos Arruda Posted May 30, 2016 Author Share Posted May 30, 2016 You are correct. I mistakenly took the GSM module model instead. The unit is a Visonic Powermax Express. Thanks. Quote Link to comment Share on other sites More sharing options...
Carlos Arruda Posted May 30, 2016 Author Share Posted May 30, 2016 Sorry. Missed the bit you said about low batteries. These have all been changed recently due to issue but error still being reported by system. Cheers. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 30, 2016 Share Posted May 30, 2016 the point at the start was check for a battery powered smoke detector not on the alarm. Where is the beep coming from? Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Carlos Arruda Posted May 30, 2016 Author Share Posted May 30, 2016 The beep is coming from the main console. There's no smoke detectors on this unit. The existing smoke/heat detectors are on a different system. Cheers. Quote Link to comment Share on other sites More sharing options...
