sixwheeledbeast Posted Wednesday at 12:31 Share Posted Wednesday at 12:31 It's not wired in the correct cable, nothing is worth saving in this case as we say. If your not going to rewire it, you'll have to go full wireless which will be new everything. 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/page/2/#findComment-531457 Share on other sites More sharing options...
bob2611 Posted Wednesday at 17:08 Author Share Posted Wednesday at 17:08 Ah I see. I can't rewire it easily. It's an apartment so the the bell box is wired all the way to the outside. What cable am I supposed to use to wire this ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/page/2/#findComment-531461 Share on other sites More sharing options...
al-yeti Posted Wednesday at 17:22 Share Posted Wednesday at 17:22 13 minutes ago, bob2611 said: Ah I see. I can't rewire it easily. It's an apartment so the the bell box is wired all the way to the outside. What cable am I supposed to use to wire this ? Scantronics will give you both wired and wireless solution , enforcer I personally think more complicated If you use FSL on the zone selection you will know which wires are faulty to an extent , and you can always put wireless in those locations Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/page/2/#findComment-531462 Share on other sites More sharing options...
sixwheeledbeast Posted Wednesday at 17:41 Share Posted Wednesday at 17:41 It looks like it's been wired in Cat5 should be "Intruder alarm cable BS4737-3.30:2015" preferably Type 2 or better, which is stranded. Solid cables are not designed for alarm systems as they can break causing intermittent faults. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/page/2/#findComment-531463 Share on other sites More sharing options...
bob2611 Posted Friday at 13:25 Author Share Posted Friday at 13:25 thank you for the replies. I will probably not rewire and go wireless. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47424-accenta-8sp400a-problem/page/2/#findComment-531464 Share on other sites More sharing options...
