July 29, 20251 yr comment_530567 Possibilities think there a instant set for part but may have to turn off the EG hallway say if it on exit route extras keypad upstairs and use instant set with hallway on turn the speaker into a 12v sounder num the speaker down with a 80-150 ohm resistor to a workable volume (comman trick on the old CandK 700L's and similar) EDIT just noticed James comment the high low sounder good shout. Edited July 29, 20251 yr by Barsnake Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530567 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr Author comment_530568 11 hours ago, al-yeti said: I guess I want to know when you enter your code and press B it gives you option for part of night set Or it does something else, will give idea what panel you got And maybe we blag our way through it I enter my code. Gives me "A=set and B=part ENT= Menu". When I select B, I then get 'P1 P2 or P3 =OFF". I select 1 and hit enter, then 30 second countdown with beeping starts. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530568 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr Author comment_530569 Just one other observation. The entire audible alert is from the keypad itself, not from the internal siren box in the hallway. Quite impressive this tiny keypad can make so much noise! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530569 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr comment_530570 3 hours ago, OneManBand said: I enter my code. Gives me "A=set and B=part ENT= Menu". When I select B, I then get 'P1 P2 or P3 =OFF". I select 1 and hit enter, then 30 second countdown with beeping starts. What's P2 then Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530570 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr Author comment_530572 28 minutes ago, al-yeti said: What's P2 then Good question. I looked in the service book. P1 is downstairs sensors, P3 is upstairs but P2 is not listed against any devices. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530572 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr comment_530574 2 hours ago, OneManBand said: Good question. I looked in the service book. P1 is downstairs sensors, P3 is upstairs but P2 is not listed against any devices. Better get rid of whole thing , it's old scrap does a job temporarily, and if you have DIY skilz then install a scantronic ion 40 But depends on wiring if it's one of those galaxy that been installed with a common leg of sorts then don't bother you will get stuck Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530574 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr comment_530576 16 or 8 plus then securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530576 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 20251 yr comment_530579 12 minutes ago, james.wilson said: 16 or 8 plus then Yeah , they threw me first time I saw that wiring that way , good thing was the data pirs of hkc saves the day Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530579 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 4, 20251 yr Author comment_530619 On 29/07/2025 at 18:30, al-yeti said: Better get rid of whole thing , it's old scrap does a job temporarily, and if you have DIY skilz then install a scantronic ion 40 But depends on wiring if it's one of those galaxy that been installed with a common leg of sorts then don't bother you will get stuck Obviously very much preference and no absolute answer, but any input on the following would be useful. Should I rip out the current wired sensors, or can I re-use them? I like the idea of not touching working sensors and wires that all run back to a central location. However, if the recommendation is put in new sensors at the same time as a new panel, then I will Is the scantronic ion 40 best choice for me? Are there any other panels I should consider? My previous home had pyronix enforcer (all wireless) and that was nice modern system If I was to install the ion 40, or an enforcer, could I DIY it? I'm fairly comptent with computing, and basic electrics and CCTV, but I've never installed an alarm panel previously. Is one more DIY friendly than the other, and can I do it without specialised tools/software which I'll likely not be able to get hands on Finally, any panels that have free remote notifications (via internet)? The pyronix had an annual app charge which if I can save on, would be nice So any advice and recommendations welcome. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530619 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 4, 20251 yr comment_530620 32 minutes ago, OneManBand said: Should I rip out the current wired sensors, or can I re-use them? I like the idea of not touching working sensors and wires that all run back to a central location. However, if the recommendation is put in new sensors at the same time as a new panel, then I will Depending on their age etc you could leave them in place. Being a galaxy they will currently be wired eol 1k 1k. Need to check your new panel will support that or you may need to chnage the jumpers/resistors inside the detectors. 33 minutes ago, OneManBand said: Is the scantronic ion 40 best choice for me? Are there any other panels I should consider? My previous home had pyronix enforcer (all wireless) and that was nice modern system Ion is a good panel but iirc the wireless side is 1 way (but im not sure never fitted one) 34 minutes ago, OneManBand said: If I was to install the ion 40, or an enforcer, could I DIY it? I'm fairly comptent with computing, and basic electrics and CCTV, but I've never installed an alarm panel previously. Is one more DIY friendly than the other, and can I do it without specialised tools/software which I'll likely not be able to get hands on You can diy anything but im sure you have seen diy in your profession. Some or ok some are terrible 35 minutes ago, OneManBand said: Finally, any panels that have free remote notifications (via internet)? The pyronix had an annual app charge which if I can save on, would be nice Be cautious with this. All apps running cost is either funded by product sales or fees. An alarm system notification cloud is a more critical system than say a lighting app or heating etc. If it goes down for a week it doesnt really matter. On an intruder alarm systm it matters a lot. Also free systems tend to be obsoleted quicker than fee based ones as additional income is required to fund it forcing new equipment to be installed and mroe ewaste. This is common in the home automation sector. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47354-yes-or-no-sounder-volume-can-be-adjusted-on-an-adt-galaxy-panel/page/2/#findComment-530620 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
