nmpuk Posted July 22, 2025 Share Posted July 22, 2025 Hi all, We’ve an eaton G2SM alarm panel and want to setup prox tags. Looking around I see the official Eaton Prox Tags but noticed a lot of generic rfid tags. Considering some of these generic rfid tags but wondering if they’re worth looking at? If so, what should I be looking for. I understand the prox tags are low frequency 125hz tags, but any suggestions on what other specific requirements i should look for? I see a lot of these are 4100 chip types. Are these compatible? thanks for the advise nate Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/ Share on other sites More sharing options...
MrHappy Posted July 22, 2025 Share Posted July 22, 2025 maybe, anything listed as galaxy, gardtec ect... will probally work, unless your buying 100's it a bit pointless 1 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530504 Share on other sites More sharing options...
nmpuk Posted July 22, 2025 Author Share Posted July 22, 2025 Thanks, seen a fair few listed as such, will check them out. One question, is there anything specific or extra secure with the original Eaton tags that would mean i should just get those? Thanks! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530505 Share on other sites More sharing options...
MrHappy Posted July 22, 2025 Share Posted July 22, 2025 I'd assume the Eaton tags to be more robust case wise than random ebay ones... 1 Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530506 Share on other sites More sharing options...
Barsnake Posted July 23, 2025 Share Posted July 23, 2025 (edited) https://www.mtecc.co.uk/products/MFLEX-tm-CLASSIC-BLUE-TAG-p445270276 Edited July 24, 2025 by james.wilson trade member is ok for links 1 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530509 Share on other sites More sharing options...
PeterJames Posted July 23, 2025 Share Posted July 23, 2025 I can sell them as trade depending on quantities cheapest would be £1.00 ea 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530510 Share on other sites More sharing options...
nmpuk Posted July 23, 2025 Author Share Posted July 23, 2025 I'd be interested, pm you? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530514 Share on other sites More sharing options...
nmpuk Posted July 31, 2025 Author Share Posted July 31, 2025 (edited) Just following on from the above. Purchased some generic prox tags from the ebay, and registered the first prox tag on the alarm fine. Unfortunately, the second prox tag throws an error that the tag is already registered. I guess thats what going generic gets me. All the six tags do the same. I'm assuming that these are all programmed with the same rfid code. Is there a quick and easy solution to this, or shall I just go an buy the Eaton originals? edit - just noticed Barsnakes's link above. Must have missed that originally. Will these have the same issue as the ebay ones I picked up? Thanks all nate. Edited July 31, 2025 by nmpuk Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530602 Share on other sites More sharing options...
PeterJames Posted August 1, 2025 Share Posted August 1, 2025 11 hours ago, nmpuk said: Just following on from the above. Purchased some generic prox tags from the ebay, and registered the first prox tag on the alarm fine. Unfortunately, the second prox tag throws an error that the tag is already registered. I guess thats what going generic gets me. All the six tags do the same. I'm assuming that these are all programmed with the same rfid code. Is there a quick and easy solution to this, or shall I just go an buy the Eaton originals? edit - just noticed Barsnakes's link above. Must have missed that originally. Will these have the same issue as the ebay ones I picked up? Thanks all nate. Did you buy them from the link I sent you? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530603 Share on other sites More sharing options...
al-yeti Posted August 1, 2025 Share Posted August 1, 2025 (edited) 12 hours ago, nmpuk said: Just following on from the above. Purchased some generic prox tags from the ebay, and registered the first prox tag on the alarm fine. Unfortunately, the second prox tag throws an error that the tag is already registered. I guess thats what going generic gets me. All the six tags do the same. I'm assuming that these are all programmed with the same rfid code. Is there a quick and easy solution to this, or shall I just go an buy the Eaton originals? edit - just noticed Barsnakes's link above. Must have missed that originally. Will these have the same issue as the ebay ones I picked up? Thanks all nate. This is normal for some selling and installing them on eaton, if you want individual serial numbers you need to tell them or pay someone or supplier more perhaps to have this , as in either bulk purchase or individual originals which cost more Edited August 1, 2025 by al-yeti Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47351-generic-prox-tags-for-eaton-alarm/#findComment-530604 Share on other sites More sharing options...
