Texecom Premier 24 Chime Setting.
Hi all.
I have a question for anyone familiar with the above mentioned panel.
In programming I'm setting up the chime on the entry / exit front door, unlike my previous panel, chime only sounds when door is opened, is there an option somewhere that will allow me to enable the chime to sound on both the opening and closing of the entry / exit door, the only options I can find for the chime are chime 1 (Single Tone) chime 2 (Double Tone) and on or off.
Regards, Dave.
can't think of any controls which chimes on change of state ?
12v buzzer on circuit mimic is something I've done before which produces a buzz until the door is closed,
kinda "state penitentiary"
I don't know of any panel that would chime on close.
Yep, as above using a Mimic output and some other logic like a toggle relay or custom outputs would be the way to go.
