Dave Walton Posted May 17 Share Posted May 17 Evening all. I have yet another question regarding my newly installed Premier Elite control panel. Question is, how do I program a particular zone to be timed when in part set ? I think I have managed to set the zones I want to be on or off when the system is part set, but I cannot find any option that allows me to program a zone as timed when part set, I can only find either on or off options. Regards, Dave. 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/ Share on other sites More sharing options...
MrHappy Posted May 17 Share Posted May 17 Guard Access ? Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529615 Share on other sites More sharing options...
Dave Walton Posted May 18 Author Share Posted May 18 14 hours ago, MrHappy said: Guard Access ? Thanks for the reply. Regarding the guard access, as far as I can make out this only allows you to pass through a zone on your way to the keypad once the entry timer has been tripped. The problem I'm having is that in part set (Going to bed) I require zones 1, 2, 3, 4, 5 and 8 (All of downstairs and upper rear bedroom windows) to be active, zone 7 (Landing) to be off and zone 6 (Stairs) to be timed. The idea being that we are able to move across the landing in the night to visit the bathroom and then when going downstairs in the morning the stairs sensor will trip the timer to remind certain individuals to disarm the system. The reason behind this is that on numerous occasions in the past these certain individuals would walk down the stairs, right past the keypad at the bottom of the said stairs and into the living room, thus triggering a full alarm and therefore awakening the whole house, by adding a sensor on the stairs that trips the timer, I hope to overcome this. (Although having known these certain individuals for quite some time, this is by no means a certainty........ !) As mentioned earlier, I can select the "Alter Part Arms" menu and select each zone to be on or off in part set, but on or off are the only options available for the zones in that menu, there are no other options like setting a zone to be timed or entry / exit. I've looked through all of the programming menus and cannot find anywhere that gives me an option to program zone 6 as timed or entry / exit when the system is part set. I'm certain that this can be done, it's just that I can't suss out how.......... So it's back over to the good folk on here to hopefully help me over the line with this one...... Regards, dave. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529625 Share on other sites More sharing options...
sixwheeledbeast Posted May 18 Share Posted May 18 It does both. Allowing walk through for Full set and switching to entry for Part sets. 1 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529627 Share on other sites More sharing options...
Dave Walton Posted May 18 Author Share Posted May 18 44 minutes ago, sixwheeledbeast said: It does both. Allowing walk through for Full set and switching to entry for Part sets. Ah......I see......, thank you.... So guard access covers both options.... As a DIY'er I haven't really much experience of a panel that has as many programming options as this has and thus I'm very grateful for the help and advice offered from the good folk on here. Your help in sorting this out for me is much appreciated. Regards, Dave. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529628 Share on other sites More sharing options...
PeterJames Posted May 19 Share Posted May 19 Glad to hear your actually using part set so many people dont. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529660 Share on other sites More sharing options...
Dave Walton Posted June 4 Author Share Posted June 4 On 19/05/2025 at 22:05, PeterJames said: Glad to hear your actually using part set so many people dont. Indeed, personally I can't get my head around people not using part set, why wouldn't you, once set up right it's great, press 2 keys, and go to bed........ In part set I have the whole of the downstairs and the two upstairs rear bedroom windows armed, (Single storey flat roof at rear so those windows are vulnerable) the landing off and the stairs timed, allows everybody to go to the loo during the night........ Link to comment https://www.thesecurityinstaller.co.uk/community/topic/47254-another-premier-elite-question/#findComment-529930 Share on other sites More sharing options...
