Connecting a Scantronic 9448+ to an from Connecting a Scantronic 9448+ to an Eaton SDR-WEXT-00 external sounder
looks like the 2 tamper loops are linked out.
Can you confirm with a meter?
Is this brand new? or from a dubious source?
I have checked with  meter that the tamper lopps are both connected.
The equipment was supplied as a kit by alertelectrical.com and it all looks to be brand new.
Great. I'd assume. It is OK then
Seems bizarre that you have a tamper fault but all switches and loops are closed
Keypad tamper is open
I simply hadn't secured the tamper switch on the control box tightly enough. Everything seems to work as expected now. Amateurs eh ?
Thanks again to you both for trying to help.
I now need to connect the sounder/strobe box. The connections aren't obvious but I'll post this as another topic in this forum I think.
  • MrHappy changed the title to Connecting a Scantronic 9448+ to an from Connecting a Scantronic 9448+ to an Eaton SDR-WEXT-00 external sounder
