Sounds like you may have been too late with the battery replacement, down power power up mains first then battery, but be warned that may get the panel back up and working (if you are lucky) it doesnt mean that the panel is okay. If the battery has been dead for a while then its likely to have done irreparable damage to the charging circuit
Register a new account
Sign in
