I am trying to set my alarm using a smart switch
I have got a RaKo Smart Lighting system and I am trying to program a switch to set my alarm and do a few other bits. I can manage all of the RaKo side of things but I need help with the alarm panel side. What outputs in the panel can I connect to in order to tell it to arm. I have got a relay that can send a signal to the alarm but don’t know where to connect up on the panel side. I have got a Texecom Premier Elite 24 Panel. Any help is much appreciated. Thanks a lot.
Try an input ??
What input should I do I don’t see any on the panel. I am quite new to this so I apologise in advanced. I am an electrician by trade and have only just start giving this stuff a go.
Haha I am dumb I just figured it out thank you all so much that helped a lot
What about the output for when the alarm is active and also an output for when the alarm is set are they a thing
Ideally you want a native integration.
Also what's the security of your automation system like
