macca4848 Posted November 14, 2022 Share Posted November 14, 2022 I've been adding bits to an Orisec system, however the 4-digit engineer code has stopped showing up the engineer menu. I know it's the right code because it recognises the 4-digits, but makes an error beep on the last digit and doesn't open up the menu - any ideas? back working on it tomorrow Quote Link to comment Share on other sites More sharing options...
al-yeti Posted November 14, 2022 Share Posted November 14, 2022 2 hours ago, macca4848 said: I've been adding bits to an Orisec system, however the 4-digit engineer code has stopped showing up the engineer menu. I know it's the right code because it recognises the 4-digits, but makes an error beep on the last digit and doesn't open up the menu - any ideas? back working on it tomorrow Did you change the code? Power cycle it? Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 15, 2022 Share Posted November 15, 2022 3 hours ago, macca4848 said: I've been adding bits to an Orisec system, however the 4-digit engineer code has stopped showing up the engineer menu. I know it's the right code because it recognises the 4-digits, but makes an error beep on the last digit and doesn't open up the menu - any ideas? back working on it tomorrow Have you set COTD to on Quote Link to comment Share on other sites More sharing options...
macca4848 Posted November 15, 2022 Author Share Posted November 15, 2022 6 hours ago, al-yeti said: Did you change the code? Power cycle it? no I didn’t change. The remote panel recognises the code as when I enter the 4th digit it does an error beep and code disappears. If I don’t enter the correct code the 4th digit doesn’t do anything and I have 4 * * * * on screen until I press enter. So I know the code is correct. Might have to powercycle it, yes Quote Link to comment Share on other sites More sharing options...
macca4848 Posted November 15, 2022 Author Share Posted November 15, 2022 5 hours ago, Imnotshankled said: Have you set COTD to on Code of The Day? Can this be done in the remote keypad? I’ve not had the control panel open as I’ve just been adding wireless zones. Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 15, 2022 Share Posted November 15, 2022 3 hours ago, macca4848 said: Code of The Day? Can this be done in the remote keypad? I’ve not had the control panel open as I’ve just been adding wireless zones. Yes yes this can be programmed in using the keypad Quote Link to comment Share on other sites More sharing options...
macca4848 Posted November 15, 2022 Author Share Posted November 15, 2022 2 hours ago, Imnotshankled said: Yes yes this can be programmed in using the keypad Ahh. I wonder if I have inadvertently done this….how would I go about getting the code of the day to reverse this. Quote Link to comment Share on other sites More sharing options...
Imnotshankled Posted November 15, 2022 Share Posted November 15, 2022 1 hour ago, macca4848 said: Ahh. I wonder if I have inadvertently done this….how would I go about getting the code of the day to reverse this. Unfortunately you can't if you have a tag to let you in engineer I can give you a COTD code the only option is to default and start fresh Quote Link to comment Share on other sites More sharing options...
MrHappy Posted November 16, 2022 Share Posted November 16, 2022 Eng code is lockable ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted November 16, 2022 Share Posted November 16, 2022 22 minutes ago, MrHappy said: Eng code is lockable ? Has basic back door I believe like many panels Quote Link to comment Share on other sites More sharing options...
