I've been adding bits to an Orisec system, however the 4-digit engineer code has stopped showing up the engineer menu.  I know it's the right code because it recognises the 4-digits, but makes an error beep on the last digit and doesn't open up the menu - any ideas?  back working on it tomorrow
Did you change the code?
Power cycle it?
Have you set COTD to on
Power cycle it?
no I didn’t change.  The remote panel recognises the code as when I enter the 4th digit it  does an error beep and code disappears.  If I don’t enter the correct code the 4th digit doesn’t do anything and I have 4 * * * * on screen until I press enter.  So I know the code is correct.
Might have to powercycle it, yes
Code of The Day?  Can this be done in the remote keypad?  I’ve not had the control panel open as I’ve just been adding wireless zones.
Yes   yes this can be programmed in using the keypad
1 hour ago, macca4848 said:
Ahh.  I wonder if I have inadvertently done this….how would I go about getting the code of the day to reverse this.
Unfortunately you can't   if you have a tag to let you in engineer I can give you a COTD code  the only option is to default and start fresh
Register a new account
Sign in
