Swapping texecom AAA1000 PIR FOR Capture AKB-0001
I have purchased 4 new ‘Capture P15 AKB-0001’ PIRs to swap out the old none cat friendly texecom AAA1000s.
I naively thought that it would be a simple task. I made a note of what wires went into which terminal and did a like for like swap with the PIRs.
After I powered the alarm back up, I got the blue light from the PIR when it detected movement but when I set the alarm it didn’t sense a thing.
OLD PIR WIRING (left to right)
0V- green
12V+ white
Alarm red
Alarm black
Tamper yellow
Tamper blue
NEW CAPTURE P15 (L to R)
0V- green
12V+ white
alarm A red
alarm B black
tamper C yellow
tamper D blue
Can anyone tell me where I’m going wrong, I would be most grateful.
thanks in advance
james
  • Replies 27
  • Views 38.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
Posted Images
The system has worked for the last 3 years. However I can’t be sure this PIR worked when armed!
The new pir didn’t light up when there was movement when armed but did when not armed
"Worked" is relative. It can seem like it works, but I mean fully functional system.
They do have a Remote LED feature but it's unlikely to be used if wired like you say.
Does the alarm activate irrelevant of the LED on the device.?
FWIW no movement sensor with be 100% pet proof, a different system design with perimeter protection would be the preferred option.
0V- green
12V+ white
Alarm red
Alarm black
Tamper yellow
Tamper blue
0V- green
12V+ white
alarm A red
alarm B black
tamper C yellow
tamper D blue
thanks in advance
james
Have you removed the EOLR links
Have you tried fitting the old PIR temporarily and testing that
Are all the other PIRs working ok
What panel do you have
Is it a veritas as it could be wired to a switched output and or the zone linked out
Edited by Imnotshankled
0V- green
12V+ white
Alarm red
Alarm black
Tamper yellow
Tamper blue
0V- green
12V+ white
alarm A red
alarm B black
tamper C yellow
tamper D blue
thanks in advance
james
Picture of new wired pir , showing inside please
And put one old pir back and see if it triggers , maybe it never worked
Thank you all for the replies.
late finish today so I haven’t been able to do anything with it.
The plan so far is
1. take a photo of the current new PIR with wiring.
2. Set the old PIR up, take a photo of the wiring and do a test to see if this triggers the alarm when it is on.
3. Test the other zones too to see if these trigger the alarm when it is on.
I took this yesterday when I had it open.
? What! I haven’t got a clue!
This topic is now closed to further replies.
