August 8, 20215 yr comment_511907 hi, How you would describe what is the Soak Test? And how the days are related to it? For example in Honeywell Galaxy there is option to set days from 1 to 14days. Would be intesting to understand the whole concept of it. Tank you Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44696-soak-testing/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 20215 yr comment_511908 soak test - an intruder alarm zone will not generate an alarm for the duration of the soak test just log' display it as a fault eg- you've a warehouse with DT900 it false alarms... you've checked the cables & the voltages blah, blah.... you reckon it might be the detector or it might be the vermin you pop a new detector on & place it on 14 day soak test, if does not FA in the next 14 days it becomes a intruder zone on the system again with no more action to take if it fails the soak test "soak failure" will be on the display & when the alarm FA'd in the middle of the night nobody got called out... Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44696-soak-testing/#findComment-511908 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 20215 yr comment_511909 Soak test is used for testing a circuit, for example a detector activates and you see no environmental reasons for the activation, you can put the circuit on soak. It will log activations but it wont alarm. So when you return check the log if it hasnt activated you can take it off soak Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44696-soak-testing/#findComment-511909 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 20215 yr comment_511918 It will also drop out of soak back into the system after the pre programmed time if no activations are recorded, iirc activations reset the timer but I may be wrong with that. Nothing is foolproof to a sufficiently talented fool. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44696-soak-testing/#findComment-511918 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
August 8, 20215 yr comment_511921 3 hours ago, norman said: It will also drop out of soak back into the system after the pre programmed time if no activations are recorded, iirc activations reset the timer but I may be wrong with that. No you are correct Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44696-soak-testing/#findComment-511921 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
