212 Posted March 20, 2021 Share Posted March 20, 2021 Hi all, i have a SD1+ fitted and has been working fine until I’ve changed the phone numbers and messages. During the test phase all registered phones ring and messages get played out, but the phone won’t ring when the alarm is triggered? Has anyone experience this issue before and managed to resolve it any advice I would be grateful. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44450-sd1-not-dialling-out/ Share on other sites More sharing options...
james.wilson Posted March 20, 2021 Share Posted March 20, 2021 Have you metered the trigger? You 100% it was working before reprogramming ie did you test it before you started. If you did you must of programmed something else securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44450-sd1-not-dialling-out/#findComment-509433 Share on other sites More sharing options...
sixwheeledbeast Posted March 20, 2021 Share Posted March 20, 2021 You need to break it down and work out why it's not triggering. So is it messed up programming in the dialler or it's input after that you know if to check output of the panel. They can get a surge up the phone line that damaged them but if test calls work that's unlikely in your case. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44450-sd1-not-dialling-out/#findComment-509435 Share on other sites More sharing options...
PeterJames Posted March 21, 2021 Share Posted March 21, 2021 20 hours ago, james.wilson said: You 100% it was working before reprogramming ie did you test it before you started. QFA these things stop working for a number of reasons, but its not normally because you changed the number unless you misspelt it Link to comment https://www.thesecurityinstaller.co.uk/community/topic/44450-sd1-not-dialling-out/#findComment-509449 Share on other sites More sharing options...
