Electrician converting to intruder alarm engineer
Hi all,
I am stepping into intruder alarms after being a sparks for nearly 20 yrs.
I am part of a firm who just does intruder alarms now and feel like an apprentice again but want to learn from the ground up... Any advice of any sort from seasoned intruder alarm installers would be much appreciated
Regards
  • Replies 52
  • Views 9.9k
  • Imnotshankled
    Imnotshankled
    Some helpful advise if you see a paragon panel rip it off the wall and stamp on it immediately
  • I converted to security about 6 years ago after being a sparks... I do prefer it but best advice I can give you is make sure you learn as much as you can from your colleagues as the information isn't
  • Don't....    you need to spend some time working at a proper co. ?
15 minutes ago, James R said:
Hi all,
Regards
I heard that it Is it a trueism that a sparks could be an alarm engineer, but an alarm engineer couldn't be a sparks... Any truth in that? Personally I believe they are 2 completely different disciplines.
Which is the 'best' intruder alarm system you have installed?
What does your company install? And can you train there ?
I converted to security about 6 years ago after being a sparks... I do prefer it but best advice I can give you is make sure you learn as much as you can from your colleagues as the information isn't as widely available on the Internet as it is for sparks. If it's just intruder alarms then there's not much to worry about but it does get complicated if you need to integrate it with CCTV and access control etc on a large commercial.
As for what's the best intruder alarm... There isn't one. If you asked 5 different alarm engineers what the best panel is they will name 5 different brands. Alarm engineers tend to fit the brands that they are experienced in and know inside out. The actual concept of an alarm is the same amongst all the brands but they all have their own menu setups and characteristics.
Euro 46 app is what i fit
Thanks. Yes, that makes sense. We use texecom premier elite - but also look after sites that have All sorts of makes/models of intruder alarms
Also into access control - networked stuff (Paxton, salto, interflex) and auto doors, gates, barriers, roller shutters etc it's like being an apprentice - again at the tender age of 35 ?
3 hours ago, Imnotshankled said:
This?
Class.  Never thought of that - however I prefer to put the joins in an ice cream tub. ?
