fob reader advise
The alarm is honeywell accenta mini g4 with lcd keypad, the Simple Set reader SS/01 is no longer available and seems to be discontinued, what other proximity fob readers can be used instead of replacing control panel and keypad.
Thanks peeps i l know it been a while hope everyone is good
  • Replies 29
  • Views 7k
  • No man   You should tell customer you cant help and if he doesn't upgrade the panel from you he will end up getting someone else to do the same thing    And walk away ?
  • Ill let Santa be the judge of that
  • What's your budget?
What's your budget?
I don't think client wants to spend more than £50 - £80 current simple set reader has failed is reason for upgrade
That is if he makes it out of lockdown ?
https://www.onlinesecurityproducts.co.uk/prox-readers-fobs.html
seen this one never used before
Yeah that looks like it will definately work with a Honeywell panel
Perfect will speak to  client
1 minute ago, PeterJames said:
no stock when you get to checkout this lockdown has really screwed up stock levels
14 minutes ago, PeterJames said:
I was joking
Is this only compatible with pyronix panel ?
