How do I get this to work?
I will attach a short movie on what the display says and a pic on how it looked before I took the old cables away.
I put the 1k resistor between 1002 and 0V to the left of 1002.
On the film it says (in Swedish):
1003 +SAB.Open circuit IR store floor
1002 +SAB.Short circuit IR store office
Not beging an alarm technician guy I just guess that 1001 (that's a door magnet) would have 1=white and 0V=Blue and the 1002 that's an PIR would be connected with 2=purple 0V=green and blue and then the white to 12V on pin 7.
  • Replies 63
  • Views 15.4k
  • Put your hand in your pocket and purchase a Pyronix Enforcer wireless  kit. Save you lots of hassle and well worth the ££.
  • Not sure id agree on the enforcer bit but its the right idea if you have no clues on what to do, wireless is ideal for DIY
  • sounds very unlikely ?
IMG_1265.MOV
Going to basics
If your remove the wiring and put a resistor in the correct place it should clear any fault that is present there
In your picture above zone 3 shows the wiring sheath isn't removed and can be a problem , did you correct that?
On 28/10/2020 at 18:10, Henrik said:
Ok guys, got everything up and running just fine.
i do however have an slight issue.
when I took the alarm down I most have missed one PIR hanging on the wall (address 1002).
how do I go about entering the engineer code to be able to delete the address 1002?
And is the engineering code always the same or is it changeable by the company who first installed the system in my old shop?
thanks in advance,
Henrik.
Another thing , show a picture of how one of your pirs is working , how is it wired and what resistors are inside it
This will help you why your not able to clear the fault on z2& z3
the picture above is the old wiring, and the film showing the new. Where would I place the resistor then to place it in the right place. :0)
Here is a pic how I wired PIR 1003 up.
Blue= Ground,
Orange= 12V
Brown= alarm
Green= tamper
Blue= Ground,
Orange= 12V
Brown= alarm
Green= tamper
What values are the resistors? As you used the tamper one to put on the panel
All I am saying if you can't clear the fault with a simple resistance, then your eol must be set different to what your putting in and it doesn't matter what sensor or cable your using , all of no consequence
What happens if you move a sensor from further up to zone two or three , it should clear the fault and send the fault to other Rio output
The resistors are Brown.brown.black.black.brown
110 ohms +/- 1%
moved 1003 to 4 and 1004 to 3 and that cleared the problem on +SAB 1003.
still got the problem on 1002 that supposed to be a PIR but still sits on the wall in my old shop.
110 ohms +/- 1%
Can't be 110 needs to be 1k I thought
Unless your saying all the zones set up that way
