New Area Code for Gardtec 800 series
We have a Gardtec 800 series installed over 20 years ago.
We have 2 areas defined such that at night time we input 'code' + 1 which excludes the landing, + 2 excludes the landing and office
We now have a dog and would like to do 'code' + 3 to exclude the kitchen
We know the kitchen is zone 2, so would like to create and area code of 3 equal to everything except zone 2
(We know we can alarm the house as required by excluding zone 2, but this is a tiny bit more complicated)
our manual says areas need to be set up by the installation company
thanks
That is correct it's something the installer would program for you, assuming a third setting can be done.
Do you have an issue getting hold of your current maintainer? I assume you have it serviced regularly by someone.
I was hoping that I could do it myself and save £100 or whatever callout + working time comes to. We do not have it serviced.
If you've never had it serviced in 20 years then standby batteries will be bust (hopefully not leaked acid all over the insides) and possibly damaged to the charging circuit.
All you need is a power cut and you have no system.
Maybe a good idea to have it looked at if you value it's purpose. Don't be surprised if recommended an upgrade or find something is bust, even if it appears to be setting fine.
Thanks. Battery was replaced a couple of years ago, but no harm and possible benefit in getting it looked over.
Anything in the engineers menu would need the code and knowledge of how to set it up, this code would need resetting.
As per our guidelines we do not provide defaulting or engineering manuals here.
It's possible , I think most competent diyers need to see if they don't need a working alarm for about let's say six weeks then you could give it ago , and call someone after if it doesn't work out
  • 2 weeks later...
