pyronix enforcer
Hey guys
So i bite the bullet and installed a pyronix enforcer v10 which seems pretty decent so far. A few things im struggling with which i hope some one can help me out. ive got 4 pirs. ive set the front door to be an entry route and also the kitchen. When setting the alarm and walk in the house through the front door (havent tried the kitchen) when the pir picks you up it automatically sets the alarm off rather than waiting the entry time before setting off. Also ive tried to set the bell delay just incase of any false alarms but again this just goes off straight away.
Any one know where im going wrong here ?
Thanks
1 hour ago, slacky said:
Hey guys
Thanks
PIR is on entry ? So it needs to be set as final entry exit whatever terminology the enforcer uses , can't remember myself
Or you meant you have a contact on the front door ? And the PIR in the hallway triggers the alarm , again it should have some attribute that knows the entry zone has been triggered giving you time to turn alarm off
Don't fit Enforcer but there will be some "access" or "walk through" setting for entry pirs.
There shouldn't be any concern with false alarms if so it's not fit for purpose.
Your not ex military are you?
think ive managed to sort it. Changed to option 10 fx / er and it seems to of done the trick
Yes FX is like an entry , if thats the only option you have
