sixwheeledbeast Posted July 15, 2020 Share Posted July 15, 2020 At a 0.25A rating (assuming that is correct value for where it came from) it will be probably be the mains supply fuse. From the events you have mentioned over the thread it's possible:- cutting through the hedge trimmer flex caused some transient on your mains popping the fuse, this allowed the battery to drain out until it failed in the early hours. Best solution to stop that in the future is petrol or electric hedge trimmers, depending on what type and how much hedge you cut. Much safer and like most cordless stuff now you'd never go back to corded afterwards. Quote Link to comment Share on other sites More sharing options...
Steve Pritchard Posted July 15, 2020 Author Share Posted July 15, 2020 29 minutes ago, sixwheeledbeast said: At a 0.25A rating (assuming that is correct value for where it came from) it will be probably be the mains supply fuse. From the events you have mentioned over the thread it's possible:- cutting through the hedge trimmer flex caused some transient on your mains popping the fuse, this allowed the battery to drain out until it failed in the early hours. Best solution to stop that in the future is petrol or electric hedge trimmers, depending on what type and how much hedge you cut. Much safer and like most cordless stuff now you'd never go back to corded afterwards. 29 minutes ago, sixwheeledbeast said: At a 0.25A rating (assuming that is correct value for where it came from) it will be probably be the mains supply fuse. From the events you have mentioned over the thread it's possible:- cutting through the hedge trimmer flex caused some transient on your mains popping the fuse, this allowed the battery to drain out until it failed in the early hours. Best solution to stop that in the future is petrol or electric hedge trimmers, depending on what type and how much hedge you cut. Much safer and like most cordless stuff now you'd never go back to corded afterwards. Thanks, totally agree on the cordless, we have chainsaw and strimmer- hedge-trimmer is in the legacy garden tool set. But the single best garden tool is the robot mower! There were two small glass fuses side by side - not the main one on the incoming, both small fuses were 0.25a Quote Link to comment Share on other sites More sharing options...
aissecur Posted July 15, 2020 Share Posted July 15, 2020 be mindful to replace them with the correct sized quick blow fuses (if you don't intend to get an installer in & DIY it) The fuses are sized to prevent damage or possible fire! Quote Link to comment Share on other sites More sharing options...
james.wilson Posted July 15, 2020 Share Posted July 15, 2020 if this 0.25A fuse on the board id suggest its the wrong size Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted July 15, 2020 Share Posted July 15, 2020 I'd agree Quote Link to comment Share on other sites More sharing options...
PeterJames Posted July 15, 2020 Share Posted July 15, 2020 6 hours ago, james.wilson said: if this 0.25A fuse on the board id suggest its the wrong size 6 hours ago, sixwheeledbeast said: I'd agree I thought it was a typo, or lack of understanding of current values the mains fuse would be higher than 250mA. I was right, Steve has confirmed that it is the PCB fuse which would not have been influenced by the hedge trimmer, unless she was trimming the carpet and caught the cables underneath or trimming around the bell box LOL Quote Link to comment Share on other sites More sharing options...
