Dialer not resetting on android
10 hours ago, james.wilson said:
On a serious note I assumed diallers would be immune from IP core changes, it appears they may not be
Yeah dialers will be obsolete when they do the changeover, unless you plug it directly into the router
  • Replies 23
  • Views 8.9k
  • sixwheeledbeast
    sixwheeledbeast
    You said that you can't clear down if it calls a landline, I would be starting to diagnose from there to make sure that is correct. I have known some devices not to sent DTMF while in a call, you
So will the cheap GSM diallers , most payasyou rates are more expensive than renting an app or having a free app in some cases
im not so sure, id say diallers will mostly still function, digi's im less sure about. But imho we shouldnt be using old tech for alarm signalling. id expect a shift to single path sim / dualpath bb and sim for everything going forward. I dont use the built in pstn on my hkc at home etc
Something on the hkc , I have seen it not respond odd occasion immediately
But seems always phone related
