Got a galaxy dimension that activates fine on all groups apart from one group...sounders assigned to that group don't activate but comms goes through fine. Had a look at all the group parameters and output programming but can't see anything out of the blue. Any suggestions? Thanks
How is the setup?
How many groups and all Sounders seperated to each group?
Or you saying common sounder doesn't activate or output only for that group doesn't activate
3 minutes ago, Logan said:
I only know galaxy 60 unfortunately
Come on Logan you don't know the galaxy 60 ?
The setup has 1 building with 2 groups, and 1 building with 1 group. The building with 1 group is seperate to the main building, with the exception that the keypad in the main building is assigned to all groups. Sounders are seperated per group.
Edited by xpertalarms
38 minutes ago, xpertalarms said:
Yep all wired correctly, correct outputs assigned. I've done an output test too and that's all fine. Very strange.....
So your saying only alarm.condition fails to trigger out put?
If the outputs are assigned correctly for that area have you got a bell delay programmed
What  does not sound e/e or alarm tones ?
www.nova-security.co.uk
www.nsiapproved.co.uk
Register a new account
Sign in
