Galaxy Mk7 Keyprox Not Working
10 hours ago, al-yeti said:
So going back it seems you think both keypads work
But are sending line 2 downstairs
Why not just put everything on to line 1?
None of the lines are working, not even line 1. If I connect my keypads to the other panel (new) it works perfectly. So I now know the issue is with the panel and it affects all the AB lines. Is there a way I can get this fixed or what could be the problem?
  • Replies 32
  • Views 9.1k
Well I assume eBay new panel doesn't work so forget it
so even if you only have 1 keypad connected on line 1 addressed as 1 it still doesnt work. Have you also tried a temp small cable just out of the panel to prove the wiring?
