MrHappy Posted June 4, 2020 Author Share Posted June 4, 2020 (edited) The soffits had been redone on one system so I could not get the lid off... I have now progessed to butchering with an angle grinder Edited June 4, 2020 by MrHappy 1 Quote Mr Veritas God Link to comment Share on other sites More sharing options...
norman Posted June 4, 2020 Share Posted June 4, 2020 1mm bit? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
MrHappy Posted June 4, 2020 Author Share Posted June 4, 2020 17 minutes ago, norman said: You're a machine diamond Quote Mr Veritas God Link to comment Share on other sites More sharing options...
norman Posted June 4, 2020 Share Posted June 4, 2020 Thanks sugartits, what about the grinder? Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
MrHappy Posted June 4, 2020 Author Share Posted June 4, 2020 diamond blade, as it was in the machine 1mm would have cut squarer... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Guest Posted June 4, 2020 Share Posted June 4, 2020 (edited) 1 hour ago, MrHappy said: The soffits had been redone on one system so I could not get the lid off... I have now progessed to butchering with an angle grinder Send it to texecom and ask for a refund i dare you 1 hour ago, MrHappy said: , ate pizza Could you send me some im hungry Edited June 4, 2020 by Guest Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 4, 2020 Share Posted June 4, 2020 Professional bell destroyer, cut so the tamper loops closed and you can access the terminals. 1 Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 4, 2020 Author Share Posted June 4, 2020 10 minutes ago, Logan said: Send it to texecom and ask for a refund i dare you its older than you! 9 minutes ago, sixwheeledbeast said: Professional bell destroyer, cut so the tamper loops closed and you can access the terminals. cut a hole & pull the piezo's off Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Guest Posted June 4, 2020 Share Posted June 4, 2020 7 minutes ago, MrHappy said: its older than you! My syncro is older than me Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted June 4, 2020 Share Posted June 4, 2020 Decent size holesaw does a good job too, done that a few times when you can't get the roofer out the bottom of a C Type. Saves pulling all the shattered plastic out the gutters and borders later... Quote Link to comment Share on other sites More sharing options...
