105tommy105 Posted March 18, 2020 Share Posted March 18, 2020 Hello, I came across a Scantronic 9600 System today, they are a bit before my time. When performing the procedure of defaulting the Engineer code due to the age the IC8 chip it was brittle and damaged. On the chip were 2 lines as follows 93CS66B1 92A422 My question is, is it as simple as getting a new chip and popping in then setting up again or is there more to it? Also found a similar post and this was recommended for the replacement chip, would this work?: https://www.google.com/search?q=24C16%2FM24C16-WBN6P+DIP-8+Serial+I²C+Bus+EEPROM&oq=24C16%2FM24C16-WBN6P+DIP-8+Serial+I²C+Bus+EEPROM&aqs=chrome..69i57j69i58&sourceid=chrome&ie=UTF-8 Thanks in advance! -Thomas Quote Link to comment Share on other sites More sharing options...
MrHappy Posted March 18, 2020 Share Posted March 18, 2020 yes, but its 20 odd year old tat... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
105tommy105 Posted March 18, 2020 Author Share Posted March 18, 2020 5 minutes ago, MrHappy said: yes, but its 20 odd year old tat... I know, it’s just to get it running before an upgrade is proposed. Just to confirm, the chip linked below will work and is just plug in and play? Thanks again Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 18, 2020 Share Posted March 18, 2020 32 minutes ago, 105tommy105 said: I know, it’s just to get it running before an upgrade is proposed. Just to confirm, the chip linked below will work and is just plug in and play? Thanks again Scrap 1 Quote Link to comment Share on other sites More sharing options...
MrHappy Posted March 18, 2020 Share Posted March 18, 2020 50 minutes ago, 105tommy105 said: I know, it’s just to get it running before an upgrade is proposed. I'd just measure the circuits, Quote Mr Veritas God Link to comment Share on other sites More sharing options...
PeterJames Posted March 18, 2020 Share Posted March 18, 2020 Most NVM chps wll do the trick but heres the one you want https://www.ebay.co.uk/itm/ST93CS66B1-STMICROELECTRONICS-ST93CS66B1/201618745648?hash=item2ef169e930:g:tHkAAOxy5QtR9ldJ Quote Link to comment Share on other sites More sharing options...
105tommy105 Posted March 18, 2020 Author Share Posted March 18, 2020 1 hour ago, PeterJames said: Most NVM chps wll do the trick but heres the one you want https://www.ebay.co.uk/itm/ST93CS66B1-STMICROELECTRONICS-ST93CS66B1/201618745648?hash=item2ef169e930:g:tHkAAOxy5QtR9ldJ Thank you! Quote Link to comment Share on other sites More sharing options...
