SW-1070 External Bell Not Sounding
  • Replies 61
  • Views 14.4k
  • buy a dog...
  • Did you set a bell delay?
  • What happens when you remove the hold off? If the bell doesnt sound then its a faulty bell, if it does, then the next thing to try is put the trigger wire to 0v if it rings then its not the cable.
Isn't the default 30 seconds, but I've never had corruption on a hkc either
Split entry is zero default , entry is 30 , perhaps he's put 30 also into split by mistake
I thought reentering the value of 0 for the bell delay had made a difference but I double checked and it hadn't so I don't think there is corruption.
On my system startup diagram,  split entry is 30 by default. I changed it to 0. I'll check later today if this rectified the problem.
He's talking about entry, we moved on from bell delay
Ok, so setting spit entry time to zero solved the problem. Now there's no delay between internal sounder and external bell activating when the entry door is opened and code isn't entered before the entry delay times out. However I still have an issue with alarmed internal doors and PIRs not activating the alarm if the entry door is opened first and these sensors are activated before the entry delay times out. So for example I open an external door,  panel starts beeping, I don't enter the code and I open an alarmed internal door. The internal sounder activates, but not the outside bell. (didn't check if there's a delay before it actually does)
Are these zones walk through by default?
Edited by Eugene's DIY Den
Not by default depends how its programmed
